Webcast-Catalyst9k
Cisco 7513 interface for 4Mbps
Hi!
I have to upgrade a cisco router 7513 to support 4 Mbps and my question is:
Which kind of Wan interface can i use?
I have a modem with V35 interface.
Thanks for your helps.
1 REPLY
Re: Cisco 7513 interface for 4Mbps
This link may help... http://www.cisco.com/en/US/products/hw/routers/ps359/prod_models_comparison.html
A HSSI interface will cater for 4M. You will require the appropriate cable though.
Hope this helps.
80
