Cisco 7513 with writing problems
I have a 7513 which can not save the actual configuration whe i try put the comand write, I receive the next error:
Building configuration...
% Cannot communicate boot variable to slave
% Cannot communicate boot variable to slave[OK]
Copying config from Master to Slave...
% Error: 37380 bytes needed in slavenvram:
only -1 bytes available.
The last modification was a change in some access-lists and a clear ip bgp.
1 REPLY
Re: Cisco 7513 with writing problems
Try the following
NWTRCHN-C75-1(config)#slave auto-sync config ---------> Turns on the
automatic synchronization mode.
NWTRCHN-C75-1(config)#end
NWTRCHN-C75-1#copy system: running-config nvram:startup-config
-------------> Saves this information to your startup configuration and
copies the configuration to the standby's startup configuration.
For more information of this, refer to below url:
http://www.cisco.com/univercd/cc/td/doc/product/core/cis7505/rte_swit/2026rsp2.htm#xtocid43
Also what IOS version are you running. Take a look at the following field notice/bug
http://www.cisco.com/warp/public/770/43.shtml
http://www.cisco.com/cgi-bin/bugtool/onebug.pl?bugid=CSCdr98566
139
