Cisco 803: DDR B-Channel Identification problem
I'm using a 803 for get into a local ISP, when establishing the connection, the link is dropped after 2 seconds. From the log, everything seems to be ok, the only error in the conversation proccess is the identification of the B-channel, find below the log:
4w0d: ISDN BR0: Outgoing call id = 0x8036, dsl 0
4w0d: ISDN BR0: Event: Call to 917529000 at 64 Kb/s
4w0d: ISDN BR0: process_bri_call(): call id 0x8036, called_number 917529000, speed 64, call type DATA
4w0d: CC_CHAN_GetIdleChanbri: dsl 0
4w0d: Found idle channel B1
4w0d: ISDN BR0: Activating
4w0d: ISDN BR0: L1 is IF_ACTIVE
4w0d: ISDN BR0: Incoming call id = 0x0013, dsl 0.
4w0d: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 65 changed to up
4w0d: ISDN BR0: TX -> SETUP pd = 8 callref = 0x2F
4w0d: Bearer Capability i = 0x8890
4w0d: Channel ID i = 0x83
4w0d: Called Party Number i = 0x80, '917529000', Plan:Unknown, Type:Unknown
4w0d: ISDN BR0: RX <- CALL_PROC pd = 8 callref = 0xAF
4w0d: Channel ID i = 0x89
4w0d: ISDN BR0: LIF_EVENT: ces/callid 1/0x8036 HOST_PROCEEDING.
4w0d: ISDN BR0: RX <- ALERTING pd = 8 callref = 0xAF
4w0d: ISDN BR0: LIF_EVENT: ces/callid 1/0x8036 HOST_ALERTING
4w0d: ISDN bchan %d, call_id %x, cause %d: DEV_CALL_PROGRESSING: VOICE ERROR: BR0(0x61A974):
4w0d: ISDN BR0: HOST_PROGRESS: VOICE ERROR: Invalid CSM info(0xFB): bchan -1, call id 8036
4w0d: ISDN BR0: RX <- CONNECT pd = 8 callref = 0xAF
4w0d: Date/Time i = 0x010B020B3602
4w0d: ISDN BR0: LIF_EVENT: ces/callid 1/0x8036 HOST_CONNECT
4w0d: %LINK-3-UPDOWN: Interface BRI0:1, changed state to up
4w0d: %DIALER-6-BIND: Interface BR0:1 bound to profile Di1
4w0d: ISDN BR0: Event: Connected to 917529000 on B1 at 64 Kb/s
4w0d: ISDN BR0: TX -> CONNECT_ACK pd = 8 callref = 0x2F
4w0d: ISDN BR0: RX <- DISCONNECT pd = 8 callref = 0xAF
4w0d: Cause i = 0x8090 - Normal call clearing
4w0d: ISDN BR0: LIF_EVENT: ces/callid 1/0x8036 HOST_DISCONNECT
4w0d: ISDN BR0: Event: Call to <unknown> was hung up.
4w0d: ISDN BR0: process_disc_ack(): call id 0x8036, ces 1, call type DATA
4w0d: %ISDN-6-DISCONNECT: Interface BRI0:1 disconnected from 917529000 , call lasted 1 seconds
4w0d: %LINK-3-UPDOWN: Interface BRI0:1, changed state to down
4w0d: %DIALER-6-UNBIND: Interface BR0:1 unbound from profile Di1.
4w0d: ISDN BR0: TX -> RELEASE pd = 8 callref = 0x2F
4w0d: ISDN BR0: RX <- RELEASE_COMP pd = 8 callref = 0xAF
4w0d: ISDN BR0: LIF_EVENT: ces/callid 1/0x8036 HOST_DISCONNECT_ACK
Any ideas on where should be the problem.
David
1 REPLY
Re: Cisco 803: DDR B-Channel Identification problem
Sounds like you are running into bug CSCdp76631 which is present in 12.0.7T. Please check your IOS and see if you are running this IOS. This bug only presents itself when placing outbound calls. Inbound works fine.
171
