Cisco 804 NAT Problem
I'm hoping someone can help me on this. I have installed a CISCO 804 ISDN Router at my mother's home. The IP address of the router on the internal network is 192.168.1.1. There are two workstations, 192.168.1.2 and 192.168.1.3. I setup the router using the ConfigMaker utility because my grasp of IOS is not that great. This generates an IOS command script that works great for general Internet browsing and e-mail. The router get's the public IP address and the workstations NAT out to the Internet just fine. BUT, I want to be able to activate my mother's ViaVideo VideoPhone so we can use that to communicate. Here are the NAT commands that worked before:
ip nat inside source static tcp 192.168.1.3 3235 207.65.178.0 3235
ip nat inside source static tcp 192.168.1.3 3234 207.65.178.0 3234
ip nat inside source static tcp 192.168.1.3 3233 207.65.178.0 3233
ip nat inside source static tcp 192.168.1.3 3232 207.65.178.0 3232
ip nat inside source static tcp 192.168.1.3 3231 207.65.178.0 3231
ip nat inside source static tcp 192.168.1.3 3230 207.65.178.0 3230
ip nat inside source static udp 192.168.1.3 3235 207.65.178.0 3235
ip nat inside source static udp 192.168.1.3 3234 207.65.178.0 3234
ip nat inside source static udp 192.168.1.3 3233 207.65.178.0 3233
ip nat inside source static udp 192.168.1.3 3232 207.65.178.0 3232
ip nat inside source static udp 192.168.1.3 3231 207.65.178.0 3231
ip nat inside source static udp 192.168.1.3 3230 207.65.178.0 3230
ip nat inside source static tcp 192.168.1.3 3603 207.65.178.0 3603
ip nat inside source static tcp 192.168.1.3 1503 207.65.178.0 1503
ip nat inside source static tcp 192.168.1.3 1720 207.65.178.0 1720
ip nat inside source static tcp 192.168.1.3 5900 207.65.178.0 5900
ip nat outside source static tcp 207.65.178.0 3235 192.168.1.3 3235
ip nat outside source static tcp 207.65.178.0 3234 192.168.1.3 3234
ip nat outside source static tcp 207.65.178.0 3233 192.168.1.3 3233
ip nat outside source static tcp 207.65.178.0 3232 192.168.1.3 3232
ip nat outside source static tcp 207.65.178.0 3231 192.168.1.3 3231
ip nat outside source static tcp 207.65.178.0 3230 192.168.1.3 3230
ip nat outside source static udp 207.65.178.0 3235 192.168.1.3 3235
ip nat outside source static udp 207.65.178.0 3234 192.168.1.3 3234
ip nat outside source static udp 207.65.178.0 3233 192.168.1.3 3233
ip nat outside source static udp 207.65.178.0 3232 192.168.1.3 3232
ip nat outside source static udp 207.65.178.0 3231 192.168.1.3 3231
ip nat outside source static udp 207.65.178.0 3230 192.168.1.3 3230
ip nat outside source static tcp 207.65.178.0 3603 192.168.1.3 3603
ip nat outside source static tcp 207.65.178.0 1503 192.168.1.3 1503
ip nat outside source static tcp 207.65.178.0 1720 192.168.1.3 1720
(Note: I've replaced the last digit in the public IP address to .0 in all cases here for security.)
When I put this into the router, Internet access is disabled on the workstations and the ViaVideo does not work. Here is the IOS script that is generated by ConfigMaker (passwords and usernames converted to ****:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname ****
enable password *****
dial-peer voice 1 pots
no call-waiting
ring 0
port 1
destination-pattern ****
dial-peer voice 2 pots
call-waiting
ring 0
port 2
pots country US
ip subnet-zero
no ip domain-lookup
isdn switch-type basic-ni
interface Ethernet0
description connected to EthernetLAN
no ip directed-broadcast
ip nat inside
interface BRI0
description connected to Internet
no ip address
ip nat outside
encapsulation ppp
dialer rotary-group 1
isdn spid1 ***
isdn spid2 ***
isdn voice-priority *** out always
isdn voice-priority *** in always
isdn voice-priority *** in off
isdn incoming-voice modem
no cdp enable
interface Dialer1
ip address 207.65.178.0 255.255.255.0
ip nat outside
encapsulation ppp
no ip split-horizon
dialer in-band
dialer idle-timeout 300
dialer string ****
dialer hold-queue 10
dialer load-threshold 1 outbound
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname *****
ppp chap password ****
ppp pap sent-username **** password ****
ppp multilink
router rip
version 2
passive-interface Dialer1
network 192.168.1.0
no auto-summary
ip nat inside source list 1 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 1 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
snmp-server location ****
snmp-server contact ****
line con 0
exec-timeout 0 0
password ****
login
transport input none
stopbits 1
line vty 0 4
password ****
login
end
Can anyone tell me what I need to change/add in my special NAT section to make this work? Any help would be GREATLY appreciated!
1 REPLY
Re: Cisco 804 NAT Problem
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
81
