Cisco 806 (12.3(1)) & Verizon DSL w/ PPPoE
I just received a Verizon DSL connection that uses PPPoE to authenticate users. I am attempting to configure my Cisco 806 to handle routing to and from the Internet handling the PPPoE authentication. I am trying to configure my router using some docs from Cisco ... but with no luck. I see the link get established but it goes right into a down state again. I have tested this with other routers... here is some info:
02:06:02: %DIALER-6-BIND: Interface Vi1 bound to profile Di1
02:06:02: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
02:06:06: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di1
02:06:06: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
02:06:12: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet1, changed state to down
And my config:
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Router
ip subnet-zero
ip dhcp excluded-address 10.10.10.1
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
partition flash 2 6 2
interface Ethernet0
ip address 10.180.1.254 255.255.255.0
ip nat inside
no cdp enable
hold-queue 32 in
hold-queue 100 out
interface Ethernet1
no ip address
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp pap sent-username <username> password <password>
ip nat inside source list 102 interface Ethernet1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
no ip http secure-server
access-list 23 permit 10.10.10.0 0.0.0.255
access-list 102 permit ip 10.10.10.0 0.0.0.255 any
line con 0
exec-timeout 120 0
stopbits 1
line vty 0 4
access-class 23 in
exec-timeout 120 0
login local
scheduler max-task-time 5000
end
Thanks!
Stefan
Bronze
Re: Cisco 806 (12.3(1)) & Verizon DSL w/ PPPoE
Stefan,
I don't know if this will fix the PPPoE issue, but your ip nat statement assigns the IP address of Ethernet 1to internal hosts, and that interface has no IP address. Change the NAT statement to "ip nat inside source list 102 interface dialer 1 overload".
Good luck.
Mark
You are using ppp authentication chap pap callin but you have no chap password or hostname.
I am not sure if that ISP uses chap or pap ( I would think Chap)
Try putting in under the dialer
ppp chap hostname (username)
ppp chap password (password)
You are also missing a dialer-list that will permit the link to come up when it see's interesting traffic.
The most common dialer-list is
dialer-list 1 protocol ip permit
Hope that helps
Travers
336
