Cisco 806 and Cable modem setup help
I am new to cisco routing and firewall configuration. I purchased a Cisco 806 to act as router and firewall. My cable modem gives out a DHCP address.
I would like to have the router recieve and address from the cable modem. Then I would like to have the router issue DHCP addresses to my LAN.
Can some one help me with this one? I have not been able to find help files or sample config files.
TNX Will
1 REPLY
Re: Cisco 806 and Cable modem setup help
Here is a config similar to one that I used on my 806 / cable modem setup:
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Router1
enable secret yourenablesecretpasswordhere
ip subnet-zero
ip dhcp pool DHCP-POOL
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
lease 5
ip inspect name myfw cuseeme timeout 3600
ip inspect name myfw ftp timeout 3600
ip inspect name myfw http timeout 3600
ip inspect name myfw rcmd timeout 3600
ip inspect name myfw realaudio timeout 3600
ip inspect name myfw smtp timeout 3600
ip inspect name myfw tftp timeout 30
ip inspect name myfw udp timeout 15
ip inspect name myfw tcp timeout 3600
ip inspect name myfw h323 timeout 3600
interface Ethernet0
description Inside interface
ip nat inside
no ip mroute-cache
no cdp enable
interface Ethernet1
description Outside interface.
ip address dhcp client-id Ethernet1
ip access-group 111 in
ip nat outside
ip inspect myfw out
no ip mroute-cache
no cdp enable
ip nat inside source route-map traffic interface Ethernet1 overload
ip classless
ip http server
access-list 50 permit 192.168.1.0 0.0.0.255
access-list 111 deny ip 192.168.1.0 0.0.0.255 any
access-list 111 deny ip 127.0.0.0 0.0.0.255 any
access-list 111 permit icmp any any echo
access-list 111 permit icmp any any echo-reply
access-list 111 permit icmp any any traceroute
access-list 111 permit udp any eq domain any
access-list 111 permit udp any eq bootps any eq bootpc
access-list 111 permit udp any eq bootps any eq bootps
access-list 111 deny ip any any log
no cdp run
banner motd ^CNo unauthorized access allowed. All access is monitored!^C
line con 0
password somepassword
logging synchronous
login
line vty 0 4
access-class 50 in
password someotherpassword
logging synchronous
login
scheduler max-task-time 5000
end
Hope it helps!
155
