Community Member
Cisco 806, Wanadoo Pro, Netissimo 2, ECI B-Focus - Prob Connection/dialer
I've wrestled with the following config for weeks but I'm never able to establish a connection. With WinRoute Pro 4.2.1 and RASPPPoE I've confirmed that the modem works and there's no problem in establishing a persistent connection. You guys/gals are my last hope: Failing here means I'll have to do something stupid and put the 806 behind the WinRoute Pro.
I've read a number of messages that claim to have no problems with the following config successfully establishing connections via an Alcatel STH modem. But in my corner of the world France Telecom, in its customary blundering way, has opted for ECI chipset DSLAMs. Consequently they supply ECI B-Focus modems.
For the record, every time I modify the startup-config, I reload
the router and restart the modem. Here's the 806 config:
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname asterix
no logging buffered
enable secret 5 --moderator edit--
enable password milou
ip subnet-zero
no ip domain-lookup
ip ssh time-out 120
ip ssh authentication-retries 3
vpdn enable
vpdn-group my-vpdn-group
protocol pppoe
ip mtu adjust
interface Ethernet0
ip address
ip nat inside
ip tcp adjust-mss 1452
no cdp enable
hold-queue 32 in
hold-queue 100 out
interface Ethernet1
no ip address
no keepalive
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Dialer0
ip address negotiated
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
no ip split-horizon
no keepalive
dialer pool 1
dialer idle-timeout 300 either
dialer enable-timeout 2
dialer hold-queue 100
dialer-group 1
no cdp enable
ppp authentication pap callin optional
ppp chap hostname fti/xxxxxxx@fti
ppp chap password 7 --moderator edit--
ppp pap sent-username fti/ xxxxxxx @fti password 7 --moderator edit--
ip nat inside source list 101 interface Dialer0 overload
ip classless
ip route Dialer0
no ip http server
ip pim bidir-enable
access-list 101 permit ip any any
dialer-list 1 protocol ip permit
line con 0
exec-timeout 0 0
stopbits 1
line vty 0 4
password rasteau
transport input none
scheduler max-task-time 5000
ntp server
The dialer seems to be functioning correctly (although I do find it strange the MTU value shows 1500 when the startup-config specifies ip mtu 1492):
asterix#sh int d0
Dialer0 is up, line protocol is up (spoofing)
Hardware is Unknown
Internet address will be negotiated using DHCP
MTU 1500 bytes, BW 56 Kbit, DLY 20000 usec,
Encapsulation PPP, loopback not set
DTR is pulsed for 1 seconds on reset
Last input never, output never, output hang never
Last clearing of "show interface" counters 18:53:09
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops:
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 42 kilobits/sec
0 packets input, 0 bytes
0 packets output, 0 bytes
The debug output:
18:52:31: Di0 DDR: ip (s=, d=, 76 bytes, outgoing
g (ip PERMIT)
18:52:31: DDR: 45C0004C 00000000 FF11F232 00000000 C26D0641 007B007B
18:52:31: DDR: 00380000 DB0006EE 00000000 00010001 00000000 00000000
18:52:31: Di0 DDR: dialer_fsm_idle()
18:52:31: Di0 DDR: Cannot place call, no dialer string set
Seeing this I said, "no dialer string set, OK, I'll put one in". Thanks to the RASPPPoe driver and the aforementioned WinRoute Pro, I found an ISDN number for the Dialup Networking connection it uses to connect to the ISP (Wanadoo). (Admittedly I also find it strange that the driver displays an ISDN connection when the ISP is providing ADSL.) But upon adding the following to the config:
asterix(config-if)#dialer string 62031050125595-BSANN201
yet again, another defeat:
18:58:55: DDR: 45C0004C 00000000 FF11F232 00000000 C26D0641 007B007B
18:58:55: DDR: 00380000 DB0006EE 00000000 00010001 00000000 00000000
18:58:55: Di0 DDR: dialer_fsm_idle()
18:58:55: Di0: No free dialer - starting fast idle timer
Is there anyone out there that can save me?
Re: Cisco 806, Wanadoo Pro, Netissimo 2, ECI B-Focus - Prob Conn
Fast Idle Timeout has the following characteristics:
1. If the session has been idling for a time period equal or greater than the fast idle timeout then the next contention call will drop the current call immediately.
2. If the session has been idling for a time period less than the fast idle timeout then the next contention call will use the fast idle timeout and wait till that fast idle timeout finishes before dropping the call.
There is a page which might make this process easier diagnose:
