Cisco 831 and NAT: problem
Hello everybody!
I've got a problem with NAT in a CISCO 831 Router. I'm NATting between the inside eth0 and the outside Dialer0 (where there's a modem that gets connected to an ISP).
The problem is that given the bare-bones setup shown below, only UDP seems to be able to pass! I can resolve domain names with nslookup, but I can't surf to any site, nor use FTP; ping too seems dead, but I read that NAT and ICMP have difficulties living together so I'm not overly worried about it.
Initially I had in place ACLs to avoid triggering on-demand routing unnecessarily, and to protect the internal network. Yet as I experienced the problems I mentioned, I removed everything to no avail.
I asked other collegues for advice but they could not spot anything wrong with the conf: can anybody help me, please?
Ezio
IOS Version: 12.2(8)YN
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname QQQQQQQ
enable secret 5 QQQQQQQQQQQQQQQ
username QQQQQQQQ privilege 15 password 7 QQQQQQQQQQQQQQQ
username QQQQQQQQ password 7 QQQQQQQQQQQQQQQQQQQQQQQQQQQQQ
ip subnet-zero
no ip domain lookup
ip audit notify log
ip audit po max-events 100
chat-script QQQQQQQQ ABORT ERROR ABORT BUSY "" "AT" OK "ATDT
555555555\T" TIMEOUT 45 CONNECT \c
modemcap entry USR_56K:MSC=X0S6=3S11=100
modemcap entry usr2:MSC=x0
interface Ethernet0
ip address 192.168.100.254 255.255.255.0
ip nat inside
no cdp enable
hold-queue 32 in
hold-queue 100 out
interface Ethernet1
no ip address
no cdp enable
interface Async1
ip address negotiated
encapsulation ppp
dialer in-band
dialer pool-member 1
async mode dedicated
ppp authentication pap callin
interface Dialer0
ip nat outside
encapsulation ppp
dialer pool 1
dialer string 555555555 modem-script QQQQQQQQQ
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp pap sent-username QQQQQQQQQQQ password QQQQQQQQQQ!
ip nat inside source list 2 interface Dialer0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
access-list 2 permit 192.168.100.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
line con 0
exec-timeout 0 0
modem enable
stopbits 1
line aux 0
exec-timeout 0 0
modem InOut
modem autoconfigure type usr2
transport input all
stopbits 1
speed 115200
flowcontrol hardware
line vty 0 4
exec-timeout 120 0
login local
length 0
scheduler max-task-time 5000
end
1 REPLY
Re: Cisco 831 and NAT: problem
Put DNS ips in config :(config)# ip name-server x.x.x.x
enable domain lookup: (config)# ip domain lookup
and check ..Hope it will help..
Thanks & Regards,
Srinivas.S
190
