Cisco 831 CRWS (web utility) not loading
Greetings. I just unwrapped my new Cisco 831 router, and everything worked out of the box (my post in this newsgroup is proof). However, when I attempt to access the CRWS web setup utility, I get a "Please wait while we check router version, IOS version, ..." and a blue progress bar infinitely fills up and re-starts-- it never allows me to get past this point and actually access the utility. My only guess is that I'm using Firefox v1.5 and this browser isn't supported-- but this would surprise me. Has anyone had this happen to them before, and does anyone have any possible solutions? Thanks in advance!
1 REPLY
Purple
Re: Cisco 831 CRWS (web utility) not loading
The system requirements for CRWS are:
* PC using the Microsoft Windows 95, Windows 98, Windows Me, Windows 2000, or Windows NT operating system.
* Netscape 4.5 or better
* IE 4.0 or better
* Java enabled on the Web browser
* Pentium II, 166 MHz or higher
* 800 by 600 screen resolution with 256 or more colors
It seems that Firefox isn't explicitly supported. Pls try IE or Netscape and see how you go.
Hope that helps - pls rate the post if it does.
Paresh,
213
