Community Member
cisco 851 LAN port restrictions
how can i restrict an ip access on the one of the LAN ports, let it be the fa0 for example.
I tryed access group but even deny any any doesn't work, i think that acl doesn't work on LAN ports, can you help me?
Re: cisco 851 LAN port restrictions
Hello there!
Never used a 851 router but judging by the following link I dont see why you could not configure the ACL on this Fe interfaces.
http://www.cisco.com/en/US/products/hw/routers/ps380/products_configuration_guide_chapter09186a008045d283.html#wp1119321
could you please paste the configurations you are using (exact words).
example on the cisco site:
interface FastEthernet4
ip address 192.168.12.2 255.255.255.0
no ip directed-broadcast (default)
speed auto
ip nat outside
ip access-group 103 in
access-list 103 permit udp host 200.1.1.1 any eq isakmp
access-list 103 permit udp host 200.1.1.1 eq isakmp any
access-list 103 permit esp host 200.1.1.1 any
access-list 103 permit icmp any any
access-list 103 deny ip any any
Please rate the post, if it helps.
Vlad
Bronze
FastEthernet4 is the routable LAN port, and the access list would indeed work here. But for ports 0 thru 3, since these are layer 2 only ports, the access list likely doesn´t work. I do not have an 851 router available to test this, so my apologies if I might be off here, but I am thinking of the following:
851#
bridge irb
interface FastEthernet0
switchport access vlan 2
interface Vlan2
bridge-group 2
interface BVI2
ip address 192.168.2.1 255.255.255.0
ip nat inside
access-group 101 in
bridge 2 protocol ieee
bridge 2 route ip
So, basically, the FastEthernet0 is bound to BVI2, which is a virtual layer 3 interface, and to which you should be able to apply the access list. Just make sure that the IP address of the client uses the IP address of BVI2 as its default gateway (and has an IP address in the same subnet).
Can you try this out ?
Nethelper
Community Member
thanks, lan is lan :) trying to use different vlans and VTP ...
113
