Cisco 851 Wlan problems
I am unable to reach the internet using SSID TKCTS. Everytime it associates it is given a IP 192.168.1.103. However my fastethernet0 connection I have setup as DHCP and I get the correct ip 192.168.112.2. What am i doing wrong. attached is my config file... Thanks..
Silver
Re: Cisco 851 Wlan problems
Do you want to assign the IP by 851 ? I found there is IP helper-address in the VLAN 1. I suspect the DHCP server of 192.168.1.5 assign the IP to you. If you want to let the 851 to assign IP, try to remove the ip help-address in VLAN1.
If I misunderstoof your case, please explain in detail.
Hope this helps.
You are correct I want the 851 to assign IPs. I will try and remove the ip help-address. This should not effect my other connections?
I removed the ip help however problem still exists.
113
