Cisco 871 Bridging and QoS
Here's a stumper for you. I have a Cisco 871 with 1 Ethernet WAN port and built-in 4 port switch. What I need to do is to use the same subnet on both the WAN and LAN/switched interfaces AND apply a QoS policy to the WAN interface.
My main problem is bridging the subnet from the WAN port to the switched ports. My attempt at this config did not work (see attached config file).
I need to get this running ASAP, since it's for a customer. Any ideas?
Thanks, in advance!
-Todd
Cisco 871 Config
version 12.3
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname tml-871
boot-start-marker
boot-end-marker
clock timezone PCTime -5
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
no aaa new-model
ip subnet-zero
no ip source-route
ip cef
ip tcp synwait-time 10
no ip bootp server
no ip domain lookup
ip domain name yourdomain.com
ip ssh time-out 60
ip ssh authentication-retries 2
ip ips po max-events 100
no ftp-server write-enable
interface FastEthernet0
no ip address
duplex full
speed 100
no cdp enable
interface FastEthernet1
no ip address
duplex full
speed 100
no cdp enable
interface FastEthernet2
no ip address
duplex full
speed 100
no cdp enable
interface FastEthernet3
no ip address
duplex full
speed 100
no cdp enable
interface FastEthernet4
description $ES_WAN$$FW_OUTSIDE$
ip address 215.52.112.62 255.255.255.224
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
traffic-shape rate 2000000 256000 256000 1000
no cdp enable
bridge-group 1
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 215.52.112.60 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
ip tcp adjust-mss 1452
bridge-group 1
ip default-gateway 215.52.112.33
ip classless
ip route 0.0.0.0 0.0.0.0 215.52.112.33
logging trap debugging
no cdp run
control-plane
bridge 1 protocol ieee
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport preferred all
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
transport output all
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
Bronze
Re: Cisco 871 Bridging and QoS
Well I'm guessing it would be something like this:
bridge 1 route ip
bridge-group 1
no ip address
interface Vlan1
no ip address
bridge-group 1
Interface BVI1
Ahh, the BVI interface, forgot about that guy. Should I use bridge irb or the default crb?
Todd
i use bridge irb myself. when i originally set mine up, i just chose that from the configuration examples.
Thanks Tekha, this works as long as you also have "bridge irb" in the config. I appreciate the help!
-Todd
551
