Cisco 876W Router - Wireless Comms Problem
I have the following physical sratus...
PC -> Wireless Card -> Router 876W (192.168.100.1)-> Sitch -> AccessPoint -> ....wireless..... -> Access Point -> Modem/Router (192.168.0.1) -> ADSL Line
On this configuration with the above IPs i have create a VLan on 876W with IP 192.168.100.1 and the some subnet has my PC 192.168.100.2.
When i am connectin to the router through a cable on Port 1 (on posrt 0 is plugged in the Switch with the Wirelless Access Point) everythink is ok and the router is routing any packet to the other network (192.168.0.1). So by asking http://192.168.100.1 from my pc i been redirect to http://192.168.0.1 and everyone is huppy.
Now i want to have the some routing when i am connecting through my PCI Wireless Card. But instead of this the only think i can see through wireless card is the router at 192.168.100.1. How can i make the router to route any packets it gets on dot1q interface to port 0, so to be able to see 192.168.0.1?
Actually i want to connect on router two user wireless and one user with cable.
Pls could somebody help me??? I am new on networking... and i am little confused...
I am sending the current config of router
--- That's the fith POST in the forum ---
Anonymous
N/A
Re: Cisco 876W Router - Wireless Comms Problem
To deploy wireless routing, first of all ur routers should be wireless supporting routers.There r some cisco routers say for example Aironet 15000 router that supports wireless routing.
So, let me know what r the routers u use?.I may want to ensure first whether they support wireless routing.
i am uploading a .doc with the topology of the network, and two config files.
The file Config_1_BVI1.txt describes the configuration with witch i am able to surf on the net (and reply to you...).
The file Config_2_Dot11Radio.txt describes the configuration that i tried to create. Unfortuinatelly is not working...
Please any good idea??? I have spend many days trying to solve my problem...
115
