Webcast-Catalyst9k
Cisco 877w - Configuration help !!!
I just bought a cisco 877w(UK)model. IOS is c870-advsecurityk9-mz.123-8.YI1.bin version. I need the following
1. Able to use lan ports x4 - on dhcp - to access internet
2. NAT enabled
3. WLAN - to access internet
4. Firewall enabled for internet access, ftp. all else block access (inbound)
What ip addressing scheme should I be using and how to configure it through CLI or SDM.
Your help will be of very great help.
Thankyou
1 REPLY
VIP Purple
Re: Cisco 877w - Configuration help !!!
have a look at the document below, it contains a sample configuration. You might not need or want the VPN part. Regarding the IP addressing, it does not really matter which address space you are using, since you will be using NAT anyway; so you could use e.g. 192.168.1.0/24.
Cisco 877 Sample Configuration
http://www.cisco.com/en/US/products/hw/routers/ps380/products_configuration_guide_chapter09186a008045d279.html
HTH,
GP
112
