Webcast-Catalyst9k
Cisco 892 PPPoE configuration with multiple static public IP from ISP
Hi all,
My company bought a cisco router and I am new with these things. I hope someone can help me.
My details are as follows:
1. I have a block of 5 Public IP addresses from the ISP.
2. The router needs to connect using PPPoE to the ISP through a modem.
3. Behind the router, there are 2 Firewalls who uses static Public IP.
4. I also need to configure the WLAN on this router.
I do not know what I am doing wrong but I can't make it work though I tried to follow the steps from the configugation manual
can someone take a look and correct the configuartion that I did:
Building configuration...
Current configuration : 5768 bytes
! Last configuration change at 06:18:01 UTC Tue Aug 19 2014 by admin
version 15.2
hostname router
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
ip cef
no ip domain lookup
ip name-server <from ISP DNS1>
ip name-server <from ISP DNS2>
no ipv6 cef
license udi pid CISCO892-K9
username admin privilege 15 secret 5 xxxxx
redundancy
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 isdn termination multidrop
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 no ip address
interface FastEthernet5
 no ip address
interface FastEthernet6
no ip address
 no shutdown
 duplex auto
 speed auto
interface FastEthernet7
no ip address
 no shutdown
 duplex auto
 speed auto
interface FastEthernet8
 description DSL interface
 no ip address
 no shutdown
 duplex auto
 speed auto
 pppoe enable group global
 pppoe-client dial-pool-number 1
interface GigabitEthernet0
 no ip address
 shutdown
 duplex auto
 speed auto
interface Vlan1
 description  FW1
 ip address x.x.x.x y.y.y.y <static public ip2>
 ip nat inside
 ip virtual-reassembly in
 ip tcp adjust-mss 1452
interface Vlan2
 description FW2
 ip address x.x.x.x y.y.y.y <static public ip3>
 ip nat inside
interface Dialer1
 ip address x.x.x.x y.y.y.y <static public ip1>
 ip mtu 1492
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp authentication chap pap callin
 ppp chap hostname xxxxx
 ppp chap password 0 XXXXX
 no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 10 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no access-list 23 permit 10.10.10.0 0.0.0.7
no cdp run
control-plane
mgcp profile default
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you
want to use.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE
PUBLICLY-KNOWN CREDENTIALS
Here are the Cisco IOS commands.
no username cisco
Replace <myuser> and <mypassword> with the username and password you want
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL
NOT BE ABLE TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
 login local
line aux 0
line vty 0 4
 access-class 23 in
 privilege level 15
 login local
 transport input telnet ssh
line vty 5 15
 access-class 23 in
 privilege level 15
 login local
end
Thanks in advance
Everyone's tags (2)
Hi , Though you have got only
Hi ,
 Though you have got only additional 5 IP address or x.x.x.x/29 from your service provider , How you have subneted it on your router ??
Have you checked your PPOE connectvity reachability towards internet from your router ??
Simialry on your NAT command , access-list 10 is missing on your configuration
interface Vlan1
 description  FW1
 ip nat inside
interface Vlan2
 description FW2
 ip nat inside
As you have got additional Public IP address for firewall , why you want to PAT for those Public segment ?? .
let me know if you need support on this .
Sandy
Hi Sandy, I have to admit
Hi Sandy,
I have to admit that I have no idea what I was doing.
Please help me fix it.
Thanks.
Hi ,Open webex session and
Hi ,
Open webex session and share me meeting invite to my contact id given in my profile
Sandy
Hi, I do not have a webex
I do not have a webex account to be able to invite you. I remove the following
interface Vlan1
 description  FW1
 ip nat inside
interface Vlan2
 description FW2
 ip nat inside
Then I try to assign the Public IP Ethernet interface but I get this error:
% IP addresses may not be configured on L2 links
Hi, Just to let you know I
Just to let you know I was able to make the PPPoE work.
Now I am trying to assign IP address on the interface when I bumped into this error
"IP addresses may not be configured on L2 links."
Can you suggest on how I should work this out??
Hi , Can you let me know ,
Hi ,
 Can you let me know , what is additional Public IP address subnet , which you have got from your service provider ??
Sandy
Hi, Thank you so much for the
Thank you so much for the attention. I was able to figure it out.
All is working now :)
Hi , What is the issue ?? .
Hi ,
 What is the issue ?? . How it was rectified .Kindly update other may get benefited
Sandy
Kindly rate for the post if its helpful
589
