Community Member
Cisco BGP Case Study #5 - Simple Question
Hello all - I'm missing something here - but I'll ask anyway... :)
Take a look at the BGP Case Studies (Case#5, Practical Design
Example) at:
Watch the wrap.
http://www.cisco.com/en/US/tech/tk648/tk365/technologies_tech_note09186a00800c95bb.shtml#example
In the beginning of the case study, I am assuming synchronization is on
as the author asks us to turn it off in the next few pages.
My issue: Take a look at the first "show ip bgp" for RTB in case study #5.
Notice this network:
Network Next Hop Metric LocPrf Weight Path
*>i203.250.13.0 203.250.13.41 0 100 0 i
Given that this route is learned via iBGP and we see the > notation, doesn't this suggest that the route is synchronized with an IGP route?
Yet, since this is an ospf route originating from a loopback interface
from RTA, it will be advertised as a /32 in OSPF.
This is where I get confused. Can BGP report that a route is
synchronized, best and valid if there isn't a corresponding route with
the exact same prefix in the IGP table assuming synchronization is on?
Am I missing something here?
TIA!
Scott
1 REPLY
Community Member
Re: Cisco BGP Case Study #5 - Simple Question
Hi Scott,
I am not sure if the problem still exists, but because it is not yet unswered I try to give you a hint: look at the Loopback interface mask - it is 24 bits long. I think this is why everything, what is written (concerning your doubts) should work.
If you already solved it, then forgive my late reaction.
Adam
377
