06-17-2014 08:33 AM - edited 03-03-2019 07:27 AM
Is the Cisco C2960G-24TC-L Catalyst Switch a 1GB switch? I am looking at using it in vSphere (ESXi, vCAC, ITBM)
thanks
Solved! Go to Solution.
06-17-2014 12:23 PM
Yes, the switch has 20 ports of 100/1000/1000 and 4 ports of combo Gigabit SFP.
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-series-switches/product_data_sheet0900aecd80322c0c.html
Regards.
06-17-2014 12:23 PM
Regards.
06-17-2014 07:30 PM
Depends if the switch can push that much traffic. Catalyst switches have very shallow buffers and were not designed for intense data traffic from servers/VMwares.
06-19-2014 10:15 AM
I also see the switch is no longer sold.
Which means - no future updates to IOS?
I have used Dell 55xx series before and they seemed to work well in the VM structure.
