Community Member
cisco cat 3560 service-policy output problem
I have just use the 3560 to replace 3550 switchs, but the cat3560 does not support the command "service-policy output" which was supported by 3550,
we have already use this command in 3550 to control the network traffic.
so there somebody knows if there an schedule to implement this command?
Thank you very much.
Silver
Re: cisco cat 3560 service-policy output problem
What software image is the switch running? It's likely that it does not support PBR.
"service-policy output" is not supported in 3560/3750 due to ASIC limitation. See if "srr-queue bandwidth limit" command will work for you
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3560/12225sed/scg/swqos.htm#wp1253412
Community Member
Thank you for you reply.
The srr-queue can't help me,for I need the rate limit like 512Kbps or 1024Kbps, only 3550 offers this feature.
I don't know why 3560 does not support this feature.
788
