cisco catalyst 2950 12.1 (22)EA4 not connecting to router
I shipped a newly configured cisco 2950 switch and walked a individual through connecting switch to uplink port to router. When the user connects cable from Dlink to port1 on switch we get no activity light on port 1. I went into switch by having crossover cable connected from new switch to old switch and change port speed and duplex and still have the same problem. User is utilizing a cat5 cable that worked on old switch. Any ideas?
Re: cisco catalyst 2950 12.1 (22)EA4 not connecting to router
you can check the status of the ports on the switch with the 'show interface fa 0/x' command.
You should see something like this if the port and cable are Ok:
#show interfaces fastEthernet 5/2
FastEthernet5/2 is up, line protocol is up (connected)
Hardware is C6k 100Mb 802.3, address is 000d.28b7.fd09 (bia 000d.28b7.fd09)
Description:
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Full-duplex, 100Mb/s
HTH.
Regards.
105
