Cisco Catalyst 2950T-24 EI - to do RATE-LIMITING per port ? HOW ?
Dear all,
I just tested Cisco Catalyst 2950 with EI image.
The vendor just upgraded the IOS from Standard Image to Enhanced Image..
My objective is :
To limit port ( traffic shapping) per port basis based on rate-limit command ( as Cisco said can be done with EI version). I want to have 128kbps,256, 512,1024 and 2048 speeds. When logon to IOS command, and went to specific interface to be configured, I can't get "rate-limit" command -> unrecognized command !!!.
Then I try to use Web based. I managed to use QoS but the min speed is 1Mbps to 100Mbps for FE port and increment of 1,2,3,4 up tp 100 Mbps. and the burst rate something like 4k to 512k !!!.
PLEASE HELP...me to rate limit the bandwidth !!!
My current version:
cisco-2950-mpsj-lib#sh ver
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(11)EA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Wed 28-Aug-02 10:25 by antonino
Image text-base: 0x80010000, data-base: 0x80528000
ROM: Bootstrap program is CALHOUN boot loader
cisco-2950-mpsj-lib uptime is 5 hours, 24 minutes
System image file is "flash:/c2950-i6q4l2-mz.121-11.EA1.bin"
cisco WS-C2950T-24 (RC32300) processor (revision G0) with 20402K bytes of memory.
Processor board ID FOC0646W1SH
Last reset from system-reset
Running Enhanced Image
24 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:0B:5F:8C:9F:C0
--More-- Motherboard assembly number: 73-6114-08
Power supply part number: 34-0965-01
Motherboard serial number: FOC06460CP1
Power supply serial number: PHI0526010Z
Model revision number: G0
Motherboard revision number: A0
Model number: WS-C2950T-24
System serial number: FOC0646W1SH
Configuration register is 0xF
cisco-2950-mpsj-lib#sh run
Building configuration...
Current configuration : 2780 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname cisco-2950-mpsj-lib
enable secret 5 $1$u9po$5QULW8JA8gVBK2FWaTp4G/
enable password abc123
class-map match-all 2048kbps
description 2048kbps
match ip dscp 0
class-map match-all 1536kbps
description 1536kbps
match ip dscp 0
class-map match-all 1024kbps
description 1024kbps
--More-- match ip dscp 0
class-map match-all 128kbps
description 128kbps
match ip dscp 0
class-map match-all 256kbps
description 256kbps
match ip dscp 0
class-map match-all 512kbps
description 512kbps
match ip dscp 0
policy-map 2048kbps
class 2048kbps
set ip dscp 0
police 4000000 262144 exceed-action drop
policy-map 1536kbps
class 1536kbps
set ip dscp 0
police 2000000 65536 exceed-action drop
policy-map 1024kbps
--More-- description 1024kbps
class 1024kbps
set ip dscp 0
police 1000000 131072 exceed-action drop
policy-map 128kbps
description 128kbps
class 128kbps
set ip dscp 0
police 1000000 65536 exceed-action dscp 0
policy-map 256kbps
description 256kbps
class 256kbps
set ip dscp 0
police 1000000 65536 exceed-action drop
policy-map 512kbps
description 512kbps
class 512kbps
set ip dscp 0
ip subnet-zero
--More-- !
interface FastEthernet0/1
no ip address
interface FastEthernet0/2
no ip address
interface FastEthernet0/3
no ip address
interface FastEthernet0/4
no ip address
interface FastEthernet0/5
no ip address
interface FastEthernet0/6
no ip address
interface FastEthernet0/7
no ip address
--More-- interface FastEthernet0/8
no ip address
interface FastEthernet0/9
no ip address
interface FastEthernet0/10
no ip address
interface FastEthernet0/11
no ip address
interface FastEthernet0/12
no ip address
interface FastEthernet0/13
no ip address
interface FastEthernet0/14
no ip address
interface FastEthernet0/15
no ip address
--More-- !
interface FastEthernet0/16
no ip address
interface FastEthernet0/17
no ip address
interface FastEthernet0/18
no ip address
interface FastEthernet0/19
no ip address
interface FastEthernet0/20
no ip address
interface FastEthernet0/21
no ip address
interface FastEthernet0/22
no ip address
interface FastEthernet0/23
--More-- no ip address
interface FastEthernet0/24
no ip address
service-policy input 128kbps
interface GigabitEthernet0/1
no ip address
interface GigabitEthernet0/2
no ip address
interface Vlan1
ip address 192.168.10.100 255.255.255.0
no ip route-cache
ip http server
line con 0
line vty 0 4
password cisco
login
--More-- line vty 5 15
password cisco
login
end
  • Other Network Infrastructure Subjects
1 REPLY
Bronze
Re: Cisco Catalyst 2950T-24 EI - to do RATE-LIMITING per port ?
Take a look through the following QoS link. To utilize these features, you must be running the enhanced software image on your switch:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12111ea1/scg/swqos.htm
891
