08-04-2003 10:41 AM - edited 03-02-2019 09:20 AM
When I try to start de image manualy it works fine.
Switch#dir bootflash:/
Directory of bootflash:/
1 -rw- 8620144 Mar 21 2002 23:55:12 cat4000-is-mz.121-13.EW.bin
61341696 bytes total (52713912 bytes free)
Switch#sh bootvar
BOOT variable = cat4000-is-mz.121-13.EW.bin,1
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Configuration register is 0x102
Switch#
08-04-2003 10:50 AM
The bootvariable is set incorrectly. Remove the existing one and add the following statement.
conf t
boot system flash bootflash:cat4000-is-mz.121-13.EW.bin
08-04-2003 11:21 AM
how do I remove it?
08-04-2003 11:25 AM
do a sh run. Your incorrect bootvariable should be something like "boot system flash:xxxxx"
Issue a "no boot system flash:xxxxx" from config mode
