Webcast-Catalyst9k
Cisco catalyst prompt rommon> what does it mean?
I only get this prompt. Enable doesn't work in this prompt. What do I need to do to get the catalyst 4506 running in a normal mode.
It came with this prompt right out of the box.
It has a supervisor IV engine.
Re: Cisco catalyst prompt rommon> what does it mean?
The above link posted by altaf007 is for a 4500 series router and not a catalyst 4500 switch.
If you have a valid image in the bootflash, boot from it. Here is a sample of me booting a switch in my lab
rommon 1 >dir bootflash:
File size Checksum File name
607260 bytes (0x9441c) 0x7e91bd22 cat4000-ios-promupgrade-121_19r_EW
9044852 bytes (0x8a0374) 0xe840742b cat4000-i9s-mz.121-19.EW
Total space = 61341696 bytes, Available = 29837696 bytes
rommon 2 >boot bootflash:cat4000-i9s-mz.121-19.EW
Rommon reg: 0x37004180
Running diags...
Decompressing the image
############################################################################################################################################################## [OK]
If you do not have a valid IOS image, you'll have to recover the Supervisor and the following page should help you
http://www.cisco.com/warp/public/473/149.html
I tried booting from image and this works without errors. When I reboot ROMMON returns.
The only thing I can see is confreg is set to 0x102.
Must it always be 0x2102 on the catalyst 4506?
0x102 should work as well. What is the bootvar set to? Can you paste the output of "dir bootflash:" and "sh bootvar"
Switch#dir bootflash:/
Directory of bootflash:/
1 -rw- 8620144 Mar 21 2002 23:55:12 cat4000-is-mz.121-13.EW.bin
61341696 bytes total (52713912 bytes free)
Switch#sh bootvar
BOOT variable = cat4000-is-mz.121-13.EW.bin,1
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Configuration register is 0x102
Switch#
764
