Webcast-Catalyst9k
Cisco Cluster Management Suite (CMS) Software is Web-based network mgmt
Is there any Cisco GUI MGMT Software already embedded in a 4506 switch?
1 ACCEPTED SOLUTION
Re: Cisco Cluster Management Suite (CMS) Software is Web-based n
Check out www.linmor.com or shoot me an email and will forward the docs you need for this. jose.burgos@linmor.com
Bronze
with sup3/sup4 of cat4500, there is none unless you have cisco works..
Was there any Mgmt software with Sup II?
You can use CMS scheme with SupII running CatOS.
(I'm using it on Cat4006.)
All you need is a browser on your PC with a proper Java plug-in, ADP file loaded to the switch flash (cat4000-cv.7-1-2.bin, e.g., the "cv" in the file name is important) additionally to the image file and "set ip http server enable" in your switch config.
Milan
1039
