Cisco Core Switch - Urgent Security Help
Dear All,
I am still new to the world of Cisco.
I have here in My Network one Core Switch 4506 with 15 Edge Switch 3560.
We configure the Core Switch with This Command :-
A- )
HO-CSW-01(config)#username design privilege 15 password kabdesign
B- )
HO-CSW-01(config)#username support privilege 5 password support
C- )
HO-CSW-01(config-line)#login local
as you can see from the commands, i do not have CISCO Secure TACKCAS.
My manager asked me to find a way to create user name & Password for each one of my user so & to be able to Print a report who login & what time he enter.
I am searching for any Product - for example microsoft if i can enable RADUIS -
Can any one Please guide me if there is a way to configure the Core Switch with login to to the IP-Address of the RADUIS or any thing, please any one update me , will highly appritiated .
1 REPLY
Silver
Re: Cisco Core Switch - Urgent Security Help
Check out the configuration guide at the link below. Hopefully this helps you out.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/secur_c/scprt1/scdathen.htm#93331
Steve
97
