we have intermittent connection problem for our citrix application. And I can see the reason for that is due to the large number of output errors in my ethernet interface.
Can anyone tell me the reason or possible improvement for me the reduce the number of that.
Please see below for the result of show interface
Ethernet0 is up, line protocol is up
Hardware is QUICC Ethernet, address is xxxx.xxxx.xxx (xxxx.xxxxx.xxxx.xxx)
Internet address is 192.168.x.254/24
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec, rely 255/255, load 1/255
Encapsulation ARPA, loopback not set, keepalive set (10 sec)
Last input 00:00:02, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue 0/40, 154 drops; input queue 0/75, 0 drops
5 minute input rate 20000 bits/sec, 19 packets/sec
5 minute output rate 37000 bits/sec, 20 packets/sec
317427088 packets input, 1279129179 bytes, 0 no buffer
Received 8217819 broadcasts, 0 runts, 0 giants, 0 throttles
1400 input errors, 4 CRC, 1396 frame, 0 overrun, 0 ignored, 0 abort
315081789 packets output, 945894490 bytes, 0 underruns
18242 output errors, 10991556 collisions, 2 interface resets
0 babbles, 58 late collision, 4931871 deferred
0 lost carrier, 0 no carrier
thanks
Raymond
