04-16-2002 08:10 PM - edited 03-01-2019 09:19 PM
How to trunk Cisco 6509 and Summit 48 port switch, I want all the VLAN's traffice to pass through
04-17-2002 04:23 AM
Extreme tags all VLANs on a trunk while Cisco Switches will not tag the native VLAN. You will need to account for this when configuring the trunk.
04-17-2002 05:00 AM
Use the standard trunking protocol 802.1Q.
04-18-2002 03:39 AM
Hi.
As Russ said Extreme switches tag every VLAN, so you should use 802.1q between the Catalyst and Extreme switches and change the native VLAN to something different than the default (VLAN 1) on the trunk port between them in order to force the Catalyst to tag VLAN 1 frames also.
Rgds.
NM
