Cisco IE3000 Alarms Not Applying
I am attempting to create an alarm for Port not Forwarding and using the Major alarm relay for a port. When I apply the changes I make on Cisco Network Assistant as well as through CLI, the changes I made are not saved. I am doing this all under a new alarm profile I created called PrimaryLink. Any ideas what could be happening? Thank you.
Everyone's tags (1)
1 REPLY
Hello,Did you find a solution
Did you find a solution for this issue?
Dash
21
