Community Member
Cisco LAN Management Tool -Help required
Hi!
we have campus Network with more than 2500 computers on our Network . Our Network Infrastructure consists of Catalyst 6509 L3 switch as Backbone switch , Catalyst 3508 GBIC switch for servers connectivity , Catalyst 4000 & Catalyst 3548 swiches for end users connectivity based on user concentration . Now we want to go for Network Monitoring tool to manage the traffic , fault finding , Graphical View of our Network . We would like to know what version of Cisco works will be suitable . Pls mention the latest Version of Cisco works and what are the Modules we need to order in Cisco works bundle.
Thanks in advance .
Raju
email: Raju@hadeed.com.sa
Community Member
Re: Cisco LAN Management Tool -Help required
You are probably looking for CiscoWorks 2000 LAN Management Solution (LMS) 2.1.
Blue
CW2000 LMS 2.1 which is the latest versions, seems suitable for you. More details can be see in the product bulletin docs at: http://www.cisco.com/warp/public/cc/pd/wr2k/. For question on how to order it, see http://www.cisco.com/warp/public/477/top_issues/jump9.html
194
