cisco module 6548
Already once I posted this question. But I didn't get proper answer.
I want to know the differences between cisco 6148 and 6548 modules.
What I know is 6548 will support Jumbo frames, QOS and hardware based CEF ( with the help of daugher card)
6148 supports inline power with the help of daugher card.
I want to see whether these daughter cards are available or not in the modules using commands.
Am right in the difference? Are there any other major changes in between them?
Please don't send links which require CCO account, which I don't have.
If you resolve my Issue you will get 5 points.
skrao
1 REPLY
Re: cisco module 6548
The 6548-GE-TX is a switch fabric enabled card. Since the Sup1a can't use a switch fabric, buying a 6548-GE-TX would be a bad idea...unless you plan to use it later with a sup2 or a sup720. So it is better to use 6148 module.
312
