05-30-2003 06:13 AM - edited 03-02-2019 07:45 AM
I have a catalyst switch with NAM in the 9'th module. Till yesterday I was able login though telnet and web interface.
Recently we upgraded the the version of the cat switch and since then I can not log in either through the telnet or the web interface.
Through web I get a " PAGE CAN NOT BE DISPLAYED " message and if I log in to the switch and then telnet the NAM, I get the login prompt. I enter the login and password but I get a login incorrect message.
Thanks in advance!
I am able to ping it fine.
Is it possible that the passowrds were reset when I copied the configuration on to ftp and back to the switch after the upgrade. But this may not be the case as I also have cisco IDS in module 4 and the previous login and password are working for it.
Solved! Go to Solution.
05-30-2003 10:20 AM
This is because you have enabled https on the NAM and not http and you're trying to access it via http -> http:/10.0.0.7. Instead you need to access it via https://10.0.0.7:
05-30-2003 07:02 AM
You can reset the telnet password with "clear module password 9" from
the switch.
05-30-2003 09:07 AM
I can login via the telent wndow, but still not through the web interface. In fact I cna not even reach the login screen, I get teh message " page can not be displayed" . I enabled the http and https servers from NAM CLI with the following commands.
ip http server enable
ip http secure server enable
Can you guide me further?
05-30-2003 09:58 AM
Web and CLI users are administered separately and Web root and guest user names are different from the CLI root and guest users. Also, if you enable https it will disbale http automatically. Do a ip http server disable and config clear on the NAM and reboot it. Once it comes back online use rmwebusers on the NAM CLI to reset the web password and then enable the http server only again.
05-30-2003 10:14 AM
I have pastes the configuration changes as I did them on NAM after doing a clear config and rebooting the system.
root@NAM.essex.edu# rmwebusers
WARNING: Doing this will stop the web server and remove
all locally defined web users from web user database.
Are you sure you want to continue (y/n) [n]? y
Disabling HTTP secure server...
Successfully disabled HTTP secure server.
All locally defined web users have been
removed from web user database.
root@NAM.essex.edu# ip http secure server enable
Enabling HTTP secure server...
No web users are configured.
Please enter a web administrator user name [admin]:
New password:
Confirm password:
User admin added.
Successfully enabled HTTP secure server.
But still I am not able to even get to the login screen through the web. I type http:/10.0.0.7 and I get the message " page can not be displayed"
05-30-2003 10:20 AM
05-30-2003 10:27 AM
Bingo!!Thanks
