Webcast-Catalyst9k
Cisco router 3662 : X.25 Configuration problem
HI All,
i need to establish connection from x.25 interface on Cisco router 3662 to x.25
interface on other cisco router without using IP address. Basically it will be X.25 cloud.
Could you help me on this.
Thanks & Regards,
Kiran Kumar
1 REPLY
Re: Cisco router 3662 : X.25 Configuration problem
The following page will give you info about back-to-back X.25 connection. IP over X.25 configuration in this example is mainly to provide a convenient tool to check the network, so you can omit ip address and x25 map ip commands. The X.25 connection will work without these commands.
http://www.cisco.com/warp/public/116/x25_back.html
Regards.
130
