Webcast-Catalyst9k
Cisco router and Port Forwarding?
Hi, I have a couple of questions, first I have a Cisco Soho 77 ADSL that I want to setup as a Web server in my PC. I tried using Dynamic DNS service http://www.dynu.com or http://www.no-ip.com and others, I think that my current config is Nat/Pat, I did a reverse mapping to my NAT, I added
"ip nat inside source static tcp 192.168.25.3 80 10.28.1.29 80 extendable" and still doesnt works, I think I need to do a port forwarding, but dont have CRWS configured. How does one set up port forwarding on the Cisco SOHO 77 router?
This is my router Configuration.
Current configuration : 1118 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Client_Name
enable secret 5 $$$$$$$$$$$$$$$$$.
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip dhcp pool dsl1
network 192.168.25.0 255.255.255.0
default-router 192.168.25.1
domain-name ISP.net.gt
dns-server x.x.x.3 216.230.128.32
interface Ethernet0
no shut
ip address 192.168.25.1 255.255.255.0
ip nat inside
interface ATM0
no shut
description Cliente_No.de Serie_DSLAM_Puerto DSLAM_ TEL
ip address 10.28.1.30 255.255.255.252
ip nat outside
no atm ilmi-keepalive
pvc 0/32
protocol ip 10.28.1.29
encapsulation aal5snap
dsl operating-mode auto
hold-queue 224 in
ip nat inside source list 101 interface ATM0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 10.28.1.29
no ip http server
access-list 101 permit ip 192.168.25.0 0.0.0.255 any
line con 0
stopbits 1
line vty 0 4
password thepassword
login
scheduler max-task-time 5000
end
The router doesn't have port forwarding configured so it just denies the connection. So I need to configure port forwarding.
Thanks for your help.
Re: Cisco router and Port Forwarding?
have you tried
ip nat inside source static tcp 192.168.25.3 80 interface ATM0 80
can you use show ip nat trans to make sure that the translation is happening from the outside? does your ISP allow port 80? try
ip nat inside source static tcp 192.168.25.3 80 interface ATM0 1700
and then try http://10.28.1.30:1700 to check if port 80 not allowed, if this works then 80 is blocked. pick any port # you want.
I added to my router config "ip nat inside source static tcp 192.168.25.3 80 interface ATM0 80", but still doesnt works, also I use "show ip nat trans", and shows up the below info. What could be the problem? Thanks for your help
Name_Client#sh ip nat trans
Pro Inside global Inside local Outside local Outside global
tcp 10.28.1.30:36668 192.168.25.3:36668 216.230.149.10:21 216.230.149.10:21
tcp 10.28.1.30:36660 192.168.25.3:36660 216.230.149.10:80 216.230.149.10:80
tcp 10.28.1.30:36661 192.168.25.3:36661 216.230.149.10:80 216.230.149.10:80
tcp 10.28.1.30:36694 192.168.25.3:36694 198.144.7.122:23 198.144.7.122:23
tcp 10.28.1.30:36664 192.168.25.3:36664 216.230.149.10:80 216.230.149.10:80
tcp 10.28.1.30:36672 192.168.25.3:36672 216.230.149.10:80 216.230.149.10:80
tcp 10.28.1.30:36686 192.168.25.3:36686 216.230.149.10:80 216.230.149.10:80
tcp 10.28.1.30:36685 192.168.25.3:36685 198.144.7.122:80 198.144.7.122:80
tcp 10.28.1.30:36712 192.168.25.3:36712 216.230.149.10:80 216.230.149.10:80
tcp 10.28.1.30:36717 192.168.25.3:36717 216.230.149.10:80 216.230.149.10:80
tcp 10.28.1.30:36727 192.168.25.3:36727 216.230.149.10:80 216.230.149.10:80
tcp 10.28.1.30:36726 192.168.25.3:36726 198.144.7.122:80 198.144.7.122:80
udp 10.28.1.30:35865 192.168.25.2:35865 66.98.158.185:33033 66.98.158.185:33033
tcp 10.28.1.30:36695 192.168.25.3:36695 24.118.52.210:443 24.118.52.210:443
tcp 10.28.1.30:36701 192.168.25.3:36701 24.118.52.210:443 24.118.52.210:443
tcp 10.28.1.30:36728 192.168.25.3:36728 24.118.52.210:443 24.118.52.210:443
tcp 10.28.1.30:1029 192.168.25.2:1029 64.246.49.60:33033 64.246.49.60:33033
tcp 10.28.1.30:36653 192.168.25.3:36653 216.239.39.99:80 216.239.39.99:80
tcp 10.28.1.30:1028 192.168.25.2:1028 80.160.91.13:80 80.160.91.13:80
tcp 10.28.1.30:80 192.168.25.3:80 --- ---
udp 10.28.1.30:35865 192.168.25.2:35865 64.246.49.61:53802 64.246.49.61:53802
udp 10.28.1.30:32776 192.168.25.3:32776 216.230.128.3:53 216.230.128.3:53
tcp 10.28.1.30:36748 192.168.25.3:36748 63.215.241.204:8245 63.215.241.204:8245
tcp 10.28.1.30:1036 192.168.25.2:1036 216.230.149.10:80 216.230.149.10:80
tcp 10.28.1.30:1065 192.168.25.2:1065 216.230.149.10:80 216.230.149.10:80
tcp 10.28.1.30:1068 192.168.25.2:1068 216.230.149.10:80 216.230.149.10:80
tcp 10.28.1.30:1070 192.168.25.2:1070 216.230.149.10:80 216.230.149.10:80
tcp 10.28.1.30:1072 192.168.25.2:1072 216.230.149.10:80 216.230.149.10:80
tcp 10.28.1.30:1074 192.168.25.2:1074 216.230.149.10:80 216.230.149.10:80
tcp 10.28.1.30:1073 192.168.25.2:1073 198.144.7.122:80 198.144.7.122:80
tcp 10.28.1.30:36745 192.168.25.3:36745 204.69.199.39:80 204.69.199.39:80
tcp 10.28.1.30:36747 192.168.25.3:36747 204.69.199.39:80 204.69.199.39:80
tcp 10.28.1.30:36749 192.168.25.3:36749 204.69.199.39:80 204.69.199.39:80
tcp 10.28.1.30:36750 192.168.25.3:36750 204.69.199.39:80 204.69.199.39:80
tcp 10.28.1.30:36752 192.168.25.3:36752 204.69.199.39:80 204.69.199.39:80
udp 10.28.1.30:33556 192.168.25.3:33556 198.144.7.122:33438 198.144.7.122:33438
udp 10.28.1.30:33556 192.168.25.3:33556 198.144.7.122:33439 198.144.7.122:33439
udp 10.28.1.30:33556 192.168.25.3:33556 198.144.7.122:33440 198.144.7.122:33440
udp 10.28.1.30:33556 192.168.25.3:33556 198.144.7.122:33441 198.144.7.122:33441
509
