Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Cisco SMB connector (found on WAN Switches)
Can any one confirm if the Cisco SMB connector is a 43 type?
These are found on MGX CESM cards etc.
Silver
Re: Cisco SMB connector (found on WAN Switches)
I think it’s a coaxial style connector like this http://www.lodanwest.com/pdf/telco%20coax%20brochure.pdf
Depends on the type of card - 4 port CESM back cards can be either BNC or DB15 connectors - depends on the back card ordered.
8 port CEMS 's for T1's use RJ48 connectors, E1 use either RJ48 or SMB connectors - again you order the type of card you want.
If you have access to the nodes do a dspcds or dspcd x to find out the type of connector.
The connector type is SMB, we have had a lot of trouble identifying this connector. If you order SMB in the UK it is a lot smaller than the one on the back card. The 43 type connector seems to fit ok (but not perfect).
Cheers
Andy
268
