Cisco switch 2900XL Input and Frame Errors
What is 2224 input errors and 2224 Frame errors on my Cisco Switch. Is this a cisco IOS bug?
My current IOS is 12.0(5)WC3B on 2900XL switch
FastEthernet0/37 is up, line protocol is up
Hardware is Fast Ethernet, address is 0007.5091.05e5 (bia 0007.5091.05e5)
Description: WinSvr2k
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 1/255, rxload 3/255
Keepalive not set
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input never, output 00:00:00, output hang never
Last clearing of "show interface" counters 5d22h
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
30 second input rate 1436000 bits/sec, 251 packets/sec
30 second output rate 691000 bits/sec, 230 packets/sec
93394039 packets input, 2149647415 bytes
Received 487023 broadcasts, 0 runts, 0 giants, 0 throttles
2224 input errors, 0 CRC, 2224 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast
53654189 packets output, 3879041418 bytes, 0 underruns
0 lost carrier, 0 no carrier
Re: Cisco switch 2900XL Input and Frame Errors
My Friend,
Its not an IOS bug. Try changing the switch port to some other port. Or it may be a problem with the PC connected to the port (NIC problem).
This might help u...
http://www.cisco.com/univercd/cc/td/doc/cisintwk/itg_v1/tr1904.htm
I suggest you fix all speed settings, these kind of errors are very common, looking at the percentage (0.02) it seems like there is nothing to realy worry about because these kind of errors can be caused by power glitches and all other kinds of emi sources.
338
