01-19-2004 08:51 AM - edited 03-02-2019 12:59 PM
I have a Cisco switches 6503 with supervisor MSFC2, IOS version 12.2, pcmcia ATA card 64 Mb, rommon 7.1(1)..
File installed cat6000-sup2k8.7-2-2.bin
And when I try to copy the IOS in the ATA card, or format the ATA card:
Format slot0:
Or
Format disk0:
The switch cant copy or format on the ATA card.
And thats happened in 2 switches with 2 different Supervisor and different ATA cards.
Other think, When I type the show version, I cant see information about the ATA cards.
Whats wrong?
the PN. is MEM-C6K-ATA-1-64=
That's
Happened when I try to format
Console> (enable) format disk0:
All sectors will be erased, proceed (y/n) [n]? y
Enter volume id (up to 31 characters): test
Format device disk0 failed (unknown device)Console> (enable)
Console> (enable) format slot0:
Unknown device mfg id (5d.75.ffffffea)error = -1
Format device slot0 failed (unspecified error)Console> (enable)
Console> (enable)
that's the
show version
PS2 Module: PWR-950-AC Serial #: ABC07496185
Mod Port Model Serial # Versions
1 2 WS-X6K-SUP2-2GE SAL0752R7UE Hw : 5.0
Fw : 7.1(1)
Fw1: 6.1(3)
Sw : 7.4(3)
Sw1: 7.4(3)
WS-F6K-PFC2 SAL0752R764 Hw : 3.4
2 16 WS-X6516-GBIC SAL0723EHCA Hw : 5.5
Fw : 6.3(1)
Sw : 7.4(3)
15 1 WS-F6K-MSFC2 SAL0749QBR6 Hw : 2.6
Fw : 12.1(19)E1
Sw : 12.1(19)E1
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 131072K 58516K 72556K 32768K 7629K 25139K 512K 265K 247K
Uptime is 0 day, 0 hour, 45 minutes
Console> (enable)
Right now, I'm not sure that the switch had the good version of ronmon.
And I found some more:
if I remove the ATA card in hot. the router display the fact, and if I re-insert the card, the same happened
I removed the module 2. (faster than upgrade) and I still have the problem with the ATA card.
Many thanks
Solved! Go to Solution.
01-21-2004 02:12 AM
Software version 7.5(1). You are currently running 7.4(3). 7.6(5) is the way to go. You can dowload the file from
01-19-2004 11:05 AM
You need 7.5(1) or higher for your ATA card support
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/relnotes/ol_1982.htm#379543
01-21-2004 02:09 AM
Version 7.5(1) of what? There ara too much versions on the sh ver . I think the Fw : 7.1(1) is the ronmon version, and that version it' fine.
You mean Sw : 7.4(3), what is that version?
Many Thanks
01-21-2004 02:12 AM
