Community Member
Cisco to UNIX problem
Hi there,
I have two Unix servers (identical) connected to a Cisco 5500 series switch on a WS-X5225R line card. Both servers are on the same VLAN so there is no routing involved. When we initiate a download from server A to server B we get around 7mb of throughput, but when we initiate it on server B to server A, we only get 3mb.
The duplex settings and speed are set to auto-negotiate on both the switch and both servers. If we try to hardcode them, we get multiple FCS errors on the switch and the server, and a throughput of only 20kb.
Any ideas would be very helpful,
Daniel,
Re: Cisco to UNIX problem
Might be a different setting of the port-priority. (high, low)
Community Member
Both are set to high !
And how about the TCP window-size on the machines. The hardware may be identical but there still remains a lot of room for differences.
A simple test might be to change over the network ports. When the same machine remains "slow" it is probably not a network-issue.
Community Member
It sounds like QFE incompatibility with CatOS switches. We had the similar problem with some of our UNIX servers and old Catalyst 2948 switches and solved it by upgrading firmware to 5.5. I know that 5000 switches use the same software with 2948s. I recommend you to use BugTool for 5000 switches and QFE compatibility issues before upgrading firmware.
Hope this helps
Green
You may have a cabling issue. If you have a good cable scanner, recheck the span to see if it's still Cat5 compliant.
If you don't have a scanner, try replacing the jumpers with known good commercial cables (no hand-made). I'd start with the cable connecting Server B and work outward from there.
Good Luck
Scott
97
