Cisco WLC 2125 and AIR-LAP1252AG-A-K9 access points
We are running into a little issue here and looking for some help. We have the Controller configured and it appears to be working properly the issue we are running into is that we can only get the above mentioned access points to only join the controller if they are plugged directly into the controller. I would assume that we should be able to plug these access points into any of our switches and they should be able to join the controller correct? Obviously there has to be a configuration issue somewhere and am hoping someone can point us in the right direction.
  • Other Network Infrastructure Subjects
1 REPLY
Hall of Fame Super Gold
Re: Cisco WLC 2125 and AIR-LAP1252AG-A-K9 access points
WAP to Switch - Access port
WLC to Switch - dot1Q trunk on the switch and tagged on the WLC side
427
