cisco works 2000 dns problem
hello friends
i installed cisco works 2000 with campus manager 3.1
on win nt server 4.0 with service pack 6
but i am using wins in my setup and no dns server
during installation it asked for dns but installation wet on without dns entry
but now after full installation
i have problems in device serach and other taska
is ther any way around
or i will havbe to install dns server
pls help me out
Silver
Re: cisco works 2000 dns problem
CW2000 requires name resolution to work properly. The issues you are seeing could be caused by failing name resolution. On Windows NT, a working DNS server in the network is strongly recommended. As an alternative you could use the Windows host file. WINS is not a supported name resolution schema.
The following must work properly:
nslookup [IP] (where [IP] is the IP address of the server)
nslookup [HOSTNAME] (where [HOSTNAME] is the name of the server)
nslookup [FQDM] (where [FQDN] is the fully qualified domain name
of the server.)
Also, all 3 must resolve to the same information!
We use windows host file and name resolution on Cw2k not work properly.
Ping using name or IP --> ok.
Nslookup using name or IP --> fail.
¿why?
132
