Community Member
Cisco Works LMS and RWM question
I've noticed that LMS and RWM solutions have some of the similar packages, Does anyone know if you can just buy one solution and add the other packages, or do I have to buy both; and if I buy both, is it possible to install both solutions on one server, any help is appreciated, thanks.
1 REPLY
Blue
Re: Cisco Works LMS and RWM question
Yes, the core applications in both bundles are same. But none of these individual application in both bundles are sold separately. Therefore, you'd need to get both and can install on the same server provided that the versions etc are the same.
94
