11-13-2002 05:10 AM - edited 03-02-2019 02:50 AM
Hi Forum,
I get the following error message when I try to monitor a 3600 router: "No such instance error on dsx1 CurrentCSSs.4"
We've got some other 3600 devices in our network, but only one of them is reporting this problem. Configuration, agents, patchs.., everything seems to be working fine, so I don't know how it comes nor how it can be fixed.
Please, any idea? Thanks in advance!
11-13-2002 05:55 AM
What is the version of CiscoView that you're using?. Make sure that you have installed the latest v15.0 device package for your 3600 in CiscoView from:
http://www.cisco.com/cgi-bin/Software/CiscoView/cvplanner.cgi
11-13-2002 08:42 AM
Sorry, I forgot to mention it: CiscoView 5.4 The Active Device Package that we've got running right now on our routers 3600 is version 14.0. But this problem with monitoring only happens with one router, the rest seems to be working properly and under the same conditions. So I'm actually not sure that upgrading the system with v15.0 package could fix this error.
But well, you are the experts... :-) Please let me know what you think about it... Thanks again!
11-13-2002 08:51 AM
You still may want to upgrade the CV device package to see if it helps. This will atleast eliminate that this issue is not due to the device package. And it's always recommended to have the latest device packages for the devices that you're managing via CV anyway.
11-14-2002 03:07 AM
First of all, thanks for your advice. I've just upgraded the device version, and the problem stays the same. What do you think it's going wrong yet?
Thanks again, regards
11-14-2002 08:11 AM
I'd suggest that you contact TAC to troubleshoot this problem further.
11-15-2002 12:30 AM
Ok, i'll do that. Thanks for your attention!
