CiscoView Graph show traffic for how long?
I am trying to use the "Monitor" feature in Ciscoview. I see Real-time traffic, how long will these utilisation be stored? ie, am I only able to view traffic for 5 mins? If not, what is the maximum duration? Pls help, thanks.
Silver
Re: CiscoView Graph show traffic for how long?
These utilizations are not stored. As soon as they leave your viewing window they are gone effectively. Hope this helps you,
Don
Blue
CiscoView does not have any database to save the data that you view using the Monitor option. What you see is what you get. There is option to Print the Graphs. If you're looking for doing historing trending etc, then nGenius RTM is the correct application for it.
169
