Webcast-Catalyst9k
CiscoView/HPOV integration issues.
I have a user who has HPOV on 1 box and CW2k on another, the integration for CV was working fine but the IP address of the CW2k box was changed, Network Node Manager was then still launching the the CV app and looking for the old IP addresss in the address bar. The http: strings in the CiscoView5.x.reg file has been changed and the integration package reinstalled but the issue still remains. Cleared cache and no entry exists for the old IP address in any hosts file.
Any ideas???
1 REPLY
Blue
Re: CiscoView/HPOV integration issues.
Re-install the Integration Utility + Adapter again on the HPOV server to see if it helps.
88
