Webcast-Catalyst9k
ciscoview problem
hi,
The software is ciscowork LMS 2.1, the version of ciscoview is 5.4. The operation system is windows 2000 server ,sp2. I have three catalyst 5509, hareware is the same, but software is different. Follow is the detail:
cat5000-sup3.4-3-1a.bin
cat5000-sup3.5-1-1.bin
cat5000-sup3.4-5-1.bin.
Now, only the switch (catalyst os is cat5000-sup3.4-5-1.bin) can display ws-x5304 corretly in the ciscoview. Others only display the module, but no status lights , console ,aux and the router etc. The ios of three modules (ws-x5304 ) is slot0:c5rsm-isv-mz.120-12.bin.
The version of Package cat5500 in the ciscoview is 1.6.
Do someone know about it ?
Thanks.
1 REPLY
Re: ciscoview problem
I hope these pages will be of some help to you:
CiscoView 5.4 Guide
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cvs/cvs_54/user_gd/index.htm
Device Display problems:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cvs/cvs_54/user_gd/ug_ch5.htm
Troubleshooting Ciscoview
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cvs/cvs_54/user_gd/ug_appa.htm
Does this require configuring the SNMP stuff on the cards..like enabling the SNMP, etc? Any more help would be appreciated!
89
