I am having problems adding a couple of switches into ciscoworks. Despite having upgraded rme to the latest version with a recent idu and upgrading the ios on these switches to the same ios i have on identical switches which have been added to ciscoworks with no problems these two remaining ones are still giving me a headache.
When i add them to rme, rme then tries to immediately archive a config from the switch via snmp, when it does this the processor on the switch hits 100% utilization and a sh proc cpu shows that 99% of this is ip snmp, the device then ends up being listed as not responding.
other switches of the same model have been upgraded with the same ios and go into ciscoworks without any problems.
I have tried increasing the snmp timeout values in ciscoworks.
any ideas
regards
mark
p.s. below is a sh ver
stam_reg#sh ver
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(6)EA2c, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Thu 28-Feb-02 14:44 by antonino
Image text-base: 0x80010000, data-base: 0x8042C000
ROM: Bootstrap program is CALHOUN boot loader
stam_reg uptime is 7 hours, 35 minutes
System restarted at 07:25:17 UTC Wed Nov 26 2003
System image file is "flash:c2950-i6q4l2-mz.121-6.EA2c.bin"
cisco WS-C2950-12 (RC32300) processor (revision C0) with 21295K bytes of memory
Processor board ID FOC0616W0Y5
Last reset from system-reset
Running Standard Image
12 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:09:7C:A7:62:C0
Motherboard assembly number: 73-5782-09
Power supply part number: 34-0965-01
Motherboard serial number: FOC06160LHL
Power supply serial number: DAB0615272Z
Model revision number: C0
Motherboard revision number: A0
Model number: WS-C2950-12
System serial number: FOC0616W0Y5
Configuration register is 0xF
