Community Member
CiscoWorks HELP!
All,
I'm getting the message below from a CiscoWorks box, but when I check the configs of the switches everything appears to be working fine... Thoughts??
Type :VTP Disconnected Domain
Severity :High
Description :DomainName:mydomain
First found :2004/04/06 08:21:22
Details
VTPDomain nso with revision number 31 is disconnected.
Set1 contains the following devices:
18.115.160.2
Set2 contains the following devices:
18.115.180.2
Set3 contains the following devices:
18.115.160.4
Set4 contains the following devices:
18.115.160.5
Set5 contains the following devices:
18.115.160.3
Set6 contains the following devices:
18.115.160.6
Set7 contains the following devices:
18.115.190.2
Blue
Re: CiscoWorks HELP!
What device?. What specific app in CiscoWorks?. Version, IDU installed?
Or better yet, how is VTP configured on your switches? What VTP Domain? What mode (transparent, client, server?).
I believe a "disconnected domain" is when you have 2 sets of switches that Ciscoworks doesn't see as connected at all, that are both running VTP with the same VTP domain name. The problem is, if these 2 groups ever get connected again, the one with the higher revision will "take over" the configuration of the one's with the older configuration. If your not using VLAN's - its not a big deal. But if you are, it could get quite messy...
Give us a "sh vtp status" on the devices and let us know how/whether they are connected.
119
