CiscoWorks installations question
Hi all together!
We've bought CW Campus + RWAN. During installations those products i have some misunderstanding and question:
1) For complite installation both products, after installing Common Services and RME, Campus and other software from ManagLANSolution, I have to install only ACL manager and Perfomane manager from RWAN bundle, don't I?
2) Anybody know how to enable CDP protocol on poinit-to-point ATM links? Core of our networks consist from c7206 routers, connected together over ATM cloud (RFC1577 IP over ATM routed encapsulation with OSPF routing beetwen them). How result - CDP continuity is broken, and Topology Services cann't build integrity map of our network.
1 REPLY
Blue
Re: CiscoWorks installations question
For 1), the installation order is listed in the respective Install Guides. CD-One/Common Services must be installed first which is requires by all CW2K apps, other applications can be installed in any order except for ACL Manager which requires that RME be installed first. Also, you don't need to install the apps which you do not plan to use.
97
