Ciscoworks LMS 2.1 - Syslog TImestamps Incorrect for Catalyst Switches
The Ciscoworks LMS2.1 is unable to reflect the timestamps correctly for Catalyst Switches.
Have anyone encountered the same problem and have a workaround solution?
Please advice. Thanks.
The setting and observation are
1.Both the switches and Ciscoworks LMS2.1 Server are in Singapore.
2. The setting on the Catayst switches are:
a) set logging timestamps enable
b) set timezone CCT
c) set logging server enable
d) set logging severity 6
e) set logging level all 6 default
3. The syslog.log in the Ciscoworks have captured the correct timestamp which reflected the actual event time
e.g Sep 19 09:44:52 CCT +08:00
4.Seems like the Ciscoworks is unable to read/interpret the raw syslog.log string and use some default offset on the timestamps.
  • Other Network Infrastructure Subjects
1 REPLY
Blue
Re: Ciscoworks LMS 2.1 - Syslog TImestamps Incorrect for Catalys
See the section 'How to Correct Syslog Timestamp' at:
http://www.cisco.com/warp/public/477/RME/rme_syslog.html
106
