Ciscoworks Reinstallation problems
Hi all,
I'm attempting to re-install Ciscoworks onto our Solaris 5.8 server, and keep getting the same erros:
Installation of <CSCOcvw1> was successful.
Application CSCOcvw1 CiscoView
ERROR: Package verification failed : CSCOcvw1 aborting.
Finished: Wed Feb 4 02:24:20 GMT 2004
===============- Software Install Tool Completed. -==============
===================- Possible Warnings/Errors Encountered -===================
Is there anyway to get more information about what maybe causing this? I've run the install/uninstall scripts several times and keep getting stopped at the same place.....
Cheers,
Mike.
1 ACCEPTED SOLUTION
Blue
Re: Ciscoworks Reinstallation problems
See the section 'Uninstalling CiscoWorks from Solaris' at: http://www.cisco.com/en/US/products/sw/cscowork/ps2425/products_configuration_example09186a0080133f4f.shtml which has the clean_system.sh script as well as the manual steps.
Blue
Absolutely perfect - exactly what I was looking for, thanks!
88
