CiscoWorks Routed Wan Mgmt Soln Integration With NNM 6.41
madan-sudhindra
We have implemented Ciscoworks RWMS and HPOV NNM 6.41 on seperate Win2K machines. The problem we are facing is that we are unable to integrate the two systems, to work as a single unit. Whenever we run the Integration utility, we get an error saying "Unable to find HPOV NNM installed".
Kindly hep with this issue
Madan Sudhindra
rmushtaq
Level 8
Level 8
You need to install the Integration Utility + Adapter on the HPOV server from:
http://www.cisco.com/kobayashi/sw-center/cw2000/cmc3rd.shtml
Is there any document that outlines the entire integration process
Madan
