Webcast-Catalyst9k
CiscoWorks Small Network Management Solution
Can anyone tell me if the 20 device limit on SNMS is set in stone or if it is an advisory limit. ie can I use SNMS to manage 25 device or will it only accept 20 in the database. Thanks
Blue
Re: CiscoWorks Small Network Management Solution
20 device limit is fixed, cannot be changed.
How about Cisco Works for Windows, is there a limit to number of supported devices on it?
Many thanks for your reply.
Do you lose much functionality on CWW than on CW SNMS?
101
